Rim size question
Rim size question
hey wassup fellaz.. how ya doing...... i have a question... i searched for it.. but i couldnt find it..... i wanted to ask..... what size rimz can we fit on our cars without modifying the suspension or lowering the car..... i want to put 18 inch chrome... but im n0t sure if they would make the suspension go bad or anything..... would i need wheel adapters?? any feedback would be hightly appreciated.... thanks alot!
any 4 lug (4x114.3) will fit your car..w/o changing suspension. Your car might look like a low rider but as long as the wheels are 4x114.3 then you can fit whatever size wheels you want.
18 will make your car ride rough and not as smooth as the stock size, 15" or was it 16"? if our stock size is 16" then 18's will be okay. if its 15" then the ride will be a bit rough. they say the highest size wheel you can go is a max of 2" more than stock size to keep that smooth stock ride.
i have a 96 3.2TL.... isnt that a 5 lug... i jus went back and counted!! lol... righ now im runnin on the stockers.. but someone offered me a great deal on some ARELLI KAZMIR'z and i was thinkin b0ut it....18'z w0uld fit without any type of modification to the suspension.. sorry. i didnt post which model i had in the previous post... but thanks again
18's will fit, preferably with a 225/40/18 tire (this will keep approx. same tire diameter). Recommend MINIMUM +40 offset, especially if you plan on lowering later, if so, go for +42 or 44. Mine are +42 and that's part of the reason I haven't lowered it yet is I am afraid it's gonna rub something fierce when I do drop it.
w/o modifying the suspension... you can fit 4 lug 18x7.5 for the 2.5 TL's and 5 lug 18x8 for the 3.2's, correct me if i'm wrong... it wouldn't make the stock suspension go bad but your car will be as high as a tuck...lol... and it will look funny like my car does right now... lol... click on signature to see my car or should i say 2.5 TL Truck...lol... the adapters will only be needed if you get a 4 lug design which i know you won't because there is a limited selection on 4 lug wheels and they make that kind of wheel in a 5 lug anyways... Oh and one more thing on the wheels... offset has to be FWD type... i'm not sure about the numbers on the offset but i've seen it somewhere in the "tire, wheels, suspension" part of the 1st gen forum...
About ride quality, to my knowledge, i think the size of the rim doesn't matter but the size of your tire does... like if you have 18" rims on your car with a 50 series tire...your ride won't be rough because the tire obsorbs most of the shock... and your suspension should obsorb the rest, but not all... if you ride on 35 series tires... your tire will obsorb very little and the vibration will transfer from the rim to the suspension making the suspension take all of it, which isn't much so you'll feel a pretty big jolt from the little pebble on the road...
k6biv
09-10-2015 06:37 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
