right turns cause thumping sound
any ideas why i hear a thumping sound when i make right turns specifically when im holding the steering wheel to the right when im exiting off a highway?
thanks
thanks
definitely cv boots or wheel bearings.. i just took mine in for that same problem.. i heard depending on the model theres a recall on it so def get that checked out before your suspension gives out
B A N N E D
if its clicking your cv joint is fucked..
Just get under the car and look at them If there is grease everywhere, just get new ones. If not then look at the bearing. Wheel bearings dont do that though.
They hum. Like if you put some super swampers on your car, it would give you a woozing hum sound.
Cv axles click and thud when you are turning. If you turn all the way and accelerate it should tell you.
Putting new boots on them is a bad idea also if its already clicking. The clicking comes from slop or play in the shaft cause its poorly lubricated. Rebooting it would be comparable to rebuilding your engine with a bad ring on brand new pistons.
rockyboy
12-06-2022 02:29 PM
