removing bumper cover
if you have a 2.5
you will need a short phillips head long phillips head flat head and either a 10mm socker or wrench
1 take the front gril off ( 3 screws phillip ) one on each side and one in the middle then you have to pull it off becareful not to break clips
2 with flathead pop the little black push thing that are under it , i think theres 5 not sure tho
3 on each side of car where the fender and bumper meet there is a screw ( feel for it , it is in the fender well) use the short phillips to take this out , (also it might make it easier to cut the wheels one way to do one side and another way to do the other side
4 there are 4( i think ) 10mm bolts under the bumper laydown on the grouns there are 2 on each side there might be push pins for the middle but some place took off my bumper b4 and i think they messed it up putting it back on
now you ahve to be careful not too mess up the paint
5 where the bumper meets fender , push down a little and pull out and that will pop out , do the same for both sides
6 its easy if another person helps you with this one , now just pull the bumperr cover off an that should be it
7 when its off take a towel or blanket and place on the ground and then rest the bumper on that to un hook the blinkers and parkinglights
good luck
good luck
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
Iakonafuji
09-21-2015 02:39 PM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
