Recalls on 1997 TL - from Alldata - transferable to second or third owners?
8th Gear
http://www.alldata.com/TSB/01/97010926.html
That site lists recalls and service bullitins for 1997 Acura TL with 3.2. Could I go to a dealership and ask them to replace/repair the recalled parts/problems would they be obliged to cover the costs?
Here's the info from the site:
Bulletins for 1997 Acura TL V6-3206cc 3.2L SOHC MFI
Safety Recalls
TSB Number Issue Date TSB Title
99-023 MAR 01 Recall - Lower Ball Joint Replacement
99-038 AUG 99 Recall - A/T Extension Shaft Sealing Bolt
Emissions Recalls
98-031 MAR 03 Recall - MIsfire Detection
Service Bulletins
04-004 FEB 04 Computers/Controls - HIM Module Updating
00-037 OCT 03 Brakes - Brake Disc Refinishing Guideline
91-050 SEP 03 Interior - Seat Belt(s) Slow to Retract
98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
97-040 MAY 03 Keyless Entry - Description/Identification/Programming
03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
02-012 MAY 02 Clutch Master Cylinder - Fluid Leakage
00-037 AUG 01 Brake Disc - Refinishing Guidelines
00-039 DEC 00 Electrical - Wiring Terminal Replacement Instructions
87-015 JUL 00 Audio System - Warranty Non Warranty Exchange/Repair
00-007 APR 00 Growling or Whining From the Rear Wheel(s)
00-008 MAR 00 Torque Converter Oil Seal Installation Tool
98-011 NOV 99 Computers/Controls - Aftermarket OBD II Tester/Software
86-014 JUN 99 Brakes - Brake Disc Refinishing Guidelines
90-007 MAY 99 Steering Wheel Off-Center Adjustment At TQI
98-031 MAR 99 Emissions System - Warranty Extension
92-009 FEB 99 Drivetrain - Creaking Noise While Turning
97-025 JUL 98 Brakes - Brake Squeal on Light Application
98-005 APR 98 CV Joint Boots - New Band & Tool
98-002 JAN 98 Cowl Drains - Sloshing Noise/Water Leaks
90-009 DEC 97 A/T - Warranty Exchange Program
87-015 NOV 97 Audio Unit In-Warranty Exchange/Out-of Warranty Repair.
90-010 OCT 97 Audio Unit Error Codes
97-027 AUG 97 Wind Noise From the Front Window
97-023 AUG 97 Window Noise During Operation
86-014 MAY 97 Brake Disc Refinishing.
97-013 MAY 97 New Halogen Leak Detector
97-015 APR 97 Interior - Driver's Footrest Too Far Away
97-017 APR 97 Mirror Housing Replacement Procedure Update
97-005 APR 97 Ignition Coil - Radio Frequency Interference
97-010 MAR 97 New Fuel Pressure Gauge and Replacement Parts
97-009 MAR 97 A/T Oil Pressure Testing Tools Update
97-007 FEB 97 TQI - Inserting additional SRS Information
97-001 FEB 97 SRS - Do it Yourself (Owner) 10 Year Inspection
96-050 NOV 96 Paint Code Crossover Part Numbers
96-039 SEP 96 Power Steering Pressure Gauge
96-033 JUL 96 SRS Inflator Simulator Tools
93-015 JUN 96 Seat Belt - Broken Tongue Stopper Button
96-010 MAR 96 Paint Finish - Minor Repairs
96-004 MAR 96 Air Conditioning System - Performance Test
96-003 FEB 96 Belt Tension Gauge Calibration and Repair
92-020 JAN 96 Front Seat Belt Replacement Warranty Policy.
92036 NOV 92 Vehicle Fails State Inspection Emissions Test
Safety Recalls
Emissions Recalls
Service Bulletins
Registered Driver
I really want to know about this one, because I believe that is the problem with my car After it rains/gets washed, there is a ton of water up front that sloshes around and slowly leaks out instead of draining at a decent rate.
Registered Driver
No update on this, though tomrorow I may go to the dealership about the one which I highlighted.
I don't know if they would be obligated to do anything about Service Bulletins, but they covered the Safety section for free for me.
Also, you can ask about an emmisions package that should include new spark plugs/wires/oil/filter change, I got mine for free
BTW: I am the second owner of my car and I had no problem.
All about JDM
The thing is, the recall is on the car itself. So it really doesnt matter who owns it cause the recalls affect the car not the owner. At least thats the way i see it.
