rear passenger window
my rear passenger window won't go up. anyone know how to pop the window switch off? i'm new at this. just trying the easy way before contacting the dealership. thanks!
Are you talking about the rear door switch that rolls the window up and down??? if so... the little tray that is next to the switch... inside that tray you will see a little cut out of some plastic cover thing... under that little cover theres a screw... take it off and you should be able to take the trim peice with the black little tray and switch off the door... wish i had a digi cam or i'd post a pic... If anyone has a digi cam and is cool enough to post a pic of what i'm trying to say... please do so... :D |
:explode: thanks...i went down there and started tinkering and figured it out. had to end up having the switch and the regulator replaced...ouch!!
