radiator flush - how often?
I had mine busted 1.5 yrs ago and never thought about flushing them. The mechanic told me to flush my radiator 2-3 times a year..???
Anybody do this?? |
that mechanic is either trying to get your business or he's some kind of extreme car buff. 2 to 3 flushes a year is way more than enough. 1 might be fine if you put alot of miles on your car in a year but its recommended that you flush your cooling system every time you change your coolant which is like every 2 years. look in your owners manual, it should tell you the recommended change interval for the coolant.
If you change coolant w/i 2 years you should never need to flush. Modern coolants have very good anti-corrosion packages. I would not contaminate my system w/ a flush unless I was going to totally remove flush by draining the block. This is a bitch to do on 2.5TL's and I just replace my coolant regularly.
good luck |
so ideally the coolant should be changed once every 2 yrs?? So by doing so, i won't have to do a complete flush, correct?
that reminds me i have to do that toooo, i havent did since 4 years ago or more..haha
I have my coolant flushed every two years.
I don't run coolant.
~Cheers~ |
