Problems with wheel nuts
I have Motegi M7 wheels and the bolt holes are very small and everytime I remove or tighten the nuts with the special socket that came with the wheels, it scrapes the inside of the holes and peels off the clearcoat.
Has anyone else had the same problem?
hmmm i hope you got the right wheel to fit your car! is your car a 2.5 or 3.2? 2.5 has a bolt pattern of 4x114.3 and 3.2 is 5x114.3. see if your wheels can fit that bolt pattern, if not....return it or sell it
I hope this is a bit clearer.
Originally posted by Din
Are you using Tuner lugs? If not maybe you should get some of those.. They should help.
cycdaniel
12-17-2019 10:58 AM
nanos
11-12-2015 08:41 PM
merc009
10-03-2015 12:59 AM
