Posting for a friend: 1998 TL, Tach sits at 3000 RPM and barely moves
That was uncalled for...
My friends 1998 TL has a problem with the Tach. When you start the car it shows the RPM at around 3000 but the engine is idling normally. The car runs and drives normally but the tachometer is always around 3000rpm. If in neutral and you rev it up a bit the needle will rise a bit to about 3250 then drop back down to 3000.
Anybody have any suggestions as to what's up?
Cheers
Cheers
Mine did that at cruising speed on the freeway- 95 freeway/5 city. (did not pay attention to city driving as I wasn't at a constant speed)
Fast forward a few months - not trying to scare you, transmission busted. Could just be coincidence. I have a AV6 in there now for 10K miles. no problems
Cheers
Cheers
Do you know if anybody disassemble the dashboard? seems like a tachometer only the problem... The tachometer have got a coil in the inside, check the coil if it not burned (With a ohmeter or multimeter).
(Sorry for my english)
rockyboy
12-06-2022 02:29 PM
urbtsx
03-04-2017 06:53 PM
mugen_kid
11-13-2015 10:38 PM
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
