Possible fix on slow windows
I don't know if you guys tried this, but I think the electric system is lacking a good ground. After putting back the head and everything else, it was lacking a good ground, gauge was blinking with the turn signals and other things. I ran a 10 gauge (i think) from the negative battery terminal to the chassis ground point, it was close to the battery. Actually the same point where the ground to the engine is at.
Also, I don't know if you guys 2.5tl have this, but at the negative wire terminal had an extra wire hang out?
It made my windows go faster. both of them. you guys can try that, hopefully it will work.
SidhuSaaB
05-30-2020 12:40 AM
