Oil Filter Gasket removal
Can anyone tell me where is it in the service manual?
I already saw the thread posted by Texas. I was just looking for some more info with picture.
I don't have access to the service manual right now. But here it is in this diagram that I've found online:
http://www.acuraautomotiveparts.org/...s=&view=normal
its a pita, just a tough spot. either remove the intake manifold to the block or use extensions that have those elbows. its where the oil filter screws in then the adapter for that screws into the block. the gasket is under $10, on difficulty from 1-10 i would give it a 3.
I don't believe it is described in the shop manual. Simple repair w/ only access being the complication. Use of swivels or wobbly extensions will solve most problems.
good luck
good luck
cycdaniel
12-17-2019 10:58 AM
