occasional deep growl/ buzz on startup
'96 3.2 TL
Sometimes when I start my car, it makes a deep growl or buzz noise for about 1 or 2 seconds and then stops. For some reason, I think its related to the ABS system? maybe I heard that somewhere?? Just wondering what the heck it is. Anyone know?
thanks, Andy
thanks, Andy
Lord Ubber
likely ABS.
I had same prob. Told by Acura dealer that it was the cyclinders in Abs sys sticking.
So I had sys flushed and it worked.
Also told that it was usual in 2.5TL's.
--or--
It could be the ABS sys cycling. Which is normal.
You could take it and see what they say. My flush was free!!
Is it like...grrrr bzzz grrr?
--or--
Hurricane Game
that is most likely the ABS unit under the hood buzzing, kicking in. if there is no ABS light on or the sounds isn't constant, i wouldn't worry about it.
Received 2,785 Likes
my car does that but only when i turn on the AC then it makes that buzzing noise for like a second then goes away, this is only when i start up the engine cold thou.
although i noticed that under hard acceleration (4k+ rpm) my ebrake light, lights up and then turns off when im not
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Registered Driver
Does it do it when you are stopped, or just after you start to move? If it makes it just after you slowly start to move, it is probably the ABS going through its self test.
Change your rear brake pads. They are too thin and your ebrake cable is being pulled tighter. When you accelerate, weight transfer pulls it even more and the light comes on.
dainmezron
10-16-2015 06:56 PM
kb1rl
09-30-2015 10:17 AM
