Need opinions on a sub box
Ex-Mod
Right now I have 2 Rockford 12" Power DVCs with a Rockford 1100A2 bridged into them at 2 ohms which is about 900 watts total. The vented box that I'm using is crappy and leaks air. I'm getting a box made by Streeteffectz but I was wondering what some of you guys did. I know the way to get the best bass is to port the box through the rear decklid but I dont want to drill a huge hole through it. Anyone have some pics of their setups to give me some ideas?
Unless you are going to port the bass through the rear deck, I would go with a sealed enclosure.
In a sedan-type car a sealed enclosure is good because intminimizes the amount of chambers. The box itself is a chamber and the trunk also acts as another chamber. Other setups bring another chamber into play.
Sealed enclosure normally require more power, but you are not lacking in the department. Your music will be more accurate and tight.
Hope it helps,
--Teflon
Hope it helps,
--Teflon
Ex-Mod
Hope it helps,
--Teflon
Hope it helps,
--Teflon
InFaMouSLink
10-30-2015 09:43 AM
