Need help with a problem from 97 TL
acuraacura
Hi All,
I need a small help with the problem I am facing. The RPM meter jumps up abruptly
even for a slight touch on the gas pedal. This problem was coming only after the Oxygen Sensor was replaced by the dealer. Every time I go they say the car is fine and no problem. And finally they said it's an old car. But it has only 88K on it.
Does this problem in any way related to the sensor that was replaced. It should be of great help to me.
Thanks in advance.
Hi All,
Thanks in advance.
Problem got solved
acuraacura
Hi Meazz,
thanks a lot for the response. I don't know how but the problem got solved and after one month again the car runs smoothly with no problem. what I was thinking is the oxygen sensor that was put would have set properly now. Thanks once again for the response.
Rgds,
Hyderabad
Hi Meazz,
Rgds,
Hyderabad
大日本帝国
So it solved itself after 2 days from your original post? Right... And you having to post the word "Acura" twice at the top of each post? Right...
~Cheers~
~Cheers~
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
