Need help 1997 TL 3.2
Old Sep 20, 2012 | 04:47 PM
hdrahms's Avatar
Bought 1997 TL 3.2 for my daughter. Has 179000 miles. Recently on her way to school, the D4 light started flashing and the speedometer stopped working. When she came out of school and started up, no problem. Has happened once since then (1 week period). Had a mechanic look at it and he had it a week and said it needs new tranny (I honestly don't even think he looked at it) Also I have a CEL for an O2 sensor. It is code P0141. Cylinder bank 1 sensor 2. Is that the post cat O2 sensor? If not, does anyone know which side O2 sensor this would be. Thanks for any information I can get.
Old Sep 22, 2012 | 08:47 AM
SmokenTL420's Avatar
probably a speed sensor issue. I'm sure one of the pros on here can give you more info on that. As for the o2 sensor I think it wil be passenger side post cat, but I may be wrong. You can always do a forum search to see if there is any info. on this issue. Good luck and you bought your daughter a great car!
Old Sep 22, 2012 | 09:15 AM
pro_found973.2TL's Avatar
your mechanic is a dumb fuck. more than likely its the speed sensor. it happend to me in my Legend.easy fix. good luck.
Old Sep 23, 2012 | 08:12 AM
Mandy's Avatar
98 3.2 Flamenco Black
D4 means tranny issue. Do a search.
Old Sep 27, 2012 | 07:38 AM
KaMLuNg's Avatar
yes D4 flashing usually means tranny issue... but it could be as simple as a VSS that needs to be replaced, or a failing trans... how is the car shifting? normal or jerky? if the speedo died, i also lean towards it being a speed sensor dying..
Old Sep 28, 2012 | 09:16 PM
Ken1997TL's Avatar
My gut feeling is it is a speed sensor issue as well that made the transmission think it's in trouble.
mlody
Dec 4, 2019 02:11 PM
Aug 15, 2019 12:58 PM
Pham Alvan
Mar 16, 2016 09:17 AM
kmarqueling
Oct 3, 2015 01:14 AM
Mike Bertram
Sep 10, 2015 09:27 AM
