More Horsepower!!
Oh yah we are also wondering what will allow it to run cooler. We have noticed that first thing in the morning it runs quicker than the afternoon when it's still cool outside. We are in Texas so the morning temp. and afternoon temp vary greatly.
if you want more h/p u can get the 6 cylinder 3.2 installed. Its possible cause my dad did it for a costumer. Its not cheap but its one way.. plus i thinik u can get more performance parts on the 6 cylinder.
Nitrous hmmm waste of money and engine. if u dont do it right ull f**k the engine and u dont watn to do that. You have to basically rebuilt ur engine to take the power(thats what i was told by lots of people that installed this mod)
So in reality there isn't much in the way of performance for these cars. Because I would like to build mine into a "Sleeper" so that when the little civics wana race I can stomp them! LOL!!! Cause there is nothing better than knowing that you are fast and luxirious! (I know I didn't spell it right it's late!)
oil cooler, fuel injector (i know aem makes them for our car), ignition isn't necessary but if you want, go for it.. uh...do the ghetto cai mod i described in the other thread. oh i know! get a manual tranny from a vigor and place that into your 2.5. actually, our cars aren't made to race but if you put in a stick for your 2.5, you'll take off from the line like no other. remember, our cars are heavy as f*ck! its well over 3k lbs.. why don't you cheat a little and ride around with no spare tire and no back seat lol
Spare tire is gone. Already and I got the NGK wires, K&N, as well as a rebuilt intake which is a little larger than stock. That's why I am so focused on improve intake. It dynoed at 198 last week but I want atleast 225. So I am hoping Oil Cooler, Fuel Regulator, Performance Injectors, and MSD ingnition will give it to it!!!
I am impressed that you went from 176 to 198 with just the KN and better intake. Even though it is just another 25, going from 200 to 225 is going to be a big jump.
In my opinion, you'll have to do some more serious work to get to that. You can mill the head (oooo risky) to get higher compression. Turn your attention to the exhaust system too. There's only so much intake can do. After that, you'll need some kind of forced induction.
Nitrous should never be used on an automatic transmission car. You just don't get enough control and you'll blow your engine.
Switch to fully synthetic motor oil if you haven't already done that. Synth will free up small amounts of power. You seem like you're after as much power as possible so every little bit helps. Change out the rear shocks to firmer ones so that more weight will stay over the front wheels during acceleration.
Take out the air conditioner, drain the washer fluid reservoir, and remove your wiper blades. Take a lug nut off of each wheel. This is what you could call a stage 1 lightening. Honda took 50 lbs off of the NSX and it became the Zanardi edition.
Well if you want to lighten your car you can also remove the shift cover over the shifter, fog light covers, spare, everything out of the glove boxes, passengers, rear seats, and air conditioner. But I want more horses so when I do that I got just a little more play room.
The 96' has a 2 Stage intake manifold unlike most other imports (Civics, ETC.) So when you increase the size going towards the cylinders you increase the air flow. With the K&N along with the little box trick as well as the NGK's the whole system is bumped up. They support each other (Well atleast the K&N and the increased intake manifold size). So all we need now is to increase the amount of intake so the manifold is used to its full extent. We are also looking into aftermarket headers of some kind. I want it to look as stock as possible in case some kid trys to take a look. That way they underestimate the car from the get go. Do you understand now????
Its a little known fact that the 2.5 liter engine is HEAVILY underrated. Honda did this because the Legend was 200 hp, you can't have the Vigor with 190 to 195 hp in a car that costs far less. Nope, so they decided to drop its hp a bit.
Oh and the 3.2 engine is underrated as well though not by much.
I agree Ken. That's why I wanted to create more horsepower in this vehicle. Its very underated within the import industry which makes it automatically the underdog in any racing situation.
Originally Posted by deluxekoncepts
huh. well I dont think I am doin a swap ne wayz just curious as to performance. But do u think an oil cooler and performance fuel injectors will help??? what about msd ignition???
Can't really put an MSD ignition on our cars, they have Coil Packs (Each spark plug is controlled with it's own coil and ignition module). You'd have to replace all 6 coils and ignition modules, wouldn't be an easy OR cheap task.....
you own a shop, a performance shop...don't you? if this is true you wouldn't be on this board trying to squeeze info out of all of us.
it IS still an internal combustion engine, even though it has five cylinders. what kind of things can you do to improve performance of an engine? if there's no aftermarket...be CREATIVE!
this is what really gets on my nerves about today's "tuner" bandwagon. it's easy to "tune" when you have boatloads of magazines with boatloads of bolt-on parts in them.
we here on this website have odd engines which nobody cares to support (aftermarket-wise). so you can either be happy with what you have, or try something new.
our engines DO still have cylinder heads...which can be ported and polished.
they have a two-piece intake manifold, which could be easily ported with the right tools (which you have, right?)
we have pistons, camshafts, ignition, spark plugs, air filters, exhaust pieces...EVERYTHING that any other engine has out there... and it is just as upgradable as any other honda engine; you just have to use your head. it will probably even benefit MORE from mods... i bet this engine is capable of screaming! just please don't rely soo heavily on aftermarket, cause we've been raped. so be creative.
and if your shop doesn't do anything but order parts from catalogs...then it's not much of a performance shop...
Heres an interesting thought I was thinking about the other day. So volvo uses 5cylinder engines as well in their older and newer cars. Then to increase their horsepower they throw on turbochargers. What I think someone should try is to find a used 5cylinder engine from a volvo and drop it. Or maybe just find out what type of turbo they use and slap that onto our powerplant. I think it makes sense.
An engine drop is difficult stuff these days because of wiring harnesses, the ECU, and all that fun stuff.
In the 60's era cars, engine swaps were a lot easier. But even then, you would stick with the same manufacturer. (You wouldn't drop a Cutlass engine into a Mustang for example)
A Volvo drop into a Honda chassis would require an insane amount of custom work. Putting on a custom turbo job would be cheaper.
Look read below we didn't only change plugs and air filter if you would read the intake manifold was ported which is what gave us most of our gain. Also MSD does make an ignition module for the 2.5 I will attach the link once I find it again. (Just to clarify)
This post is such BS. I have been modding cars for years, from mustangs in 93, then a 93 integra in 1995 (prob one of first whities in Dallas to rice and turbo an integra).
All those years I hear idiots who know NOTHING about cars say "uh I added an K & N filter and exhaust and got 20 hp"
Newsflash --> If you took a 1996-1998 3.2 TL and added AEM CAI, fabricated a crankshaft underdrive pulley, and ceramic headers, you MAY have just added 20 HP. Your 3.2TL has 200HP at the crank, that means at the wheels it is putting out ALOT LESS. With that extra 20 hp the pulley, header and CAI give, you may have 200 hp at wheels.
Sorry I gotta open a can of whoop azz on this one, but:
K&N = a few if any HP
Exhaust = 2-3 hp (or even loss of HP if wrong car)
Computer chips = higher rev and not true hp
If you want the HP you gotta pay
pulleys, CAI, headers, remove cat................then go into the engine
ay if you take out you ac and powersteerind and messed with the ecu and redo your timing youll gain horsepower. also ever thought of port and polish. remember our cars are obd2 the best way to gain more horses and torque after mods is to mess with the ecu.
Originally Posted by UnsanePyro
Hmm, what about something better for the fuel system too, new (higher flowing/more consistant/stronger) fuel pump, crap like that?
09-25-2015 06:14 PM
09-14-2015 10:48 AM
