moisture in my inspire tails.... help!
There is moisture getting inside the clear part of the tails (with the signal/reverse lights), but the outer red area (taillight part) looks fine. Obviously they are sectioned off, but where is the moisture coming from? I want to seal it up but I'm not sure where to look.
check if your trunk(where the spare tire is) has water, if yes then your tailight seal is degraded. Get a new gasket and that should solve your problem, oh and u may need to use a hair dryer to get the moisture out of the tail light
InFaMouSLink
10-27-2015 06:51 PM
