Loose Armrest
7th Gear
Loose Armrest
My armrest is loose, any way of tightening it with out removing the whole center console.
There are two compartments that open on the armrest, it is the bottom one that is loose. There are two screws holding it down, but it looks like they have to be tightened from the bottom.
Thanks for any help in advance.
AccRight
AccRight
mine's doing the same thing- @#$& thing is OFF. just kinda sit it in the holes- lol- much as i do to that car, u'd think i'd take 30 minutes to fix that- GRRR.. one day soon...
Received 2,329 Likes
Yeah, you have to take the center console apart
Its a pain to do and I need to do it soon as I now have the same problem.
that funny i think everyones seems to have that problem including me. mine is not that bad so i think im going to leave it plus im to lazy to remove the hole concole
WDP- lovin' every minute!
2 phillips screws on side of armrest(put seat all the way back and u will c the screws on the side), open up bottom half of arm rest take out lil carpet will find a plastic square or such, take off, there will be another screw underneath. take off coin tray another phillips screw there. to completely take it off i had to unscrew my shift knob and take out the gear indicator (P,R,N D1 etc) also put parking brake to highest possible position to slide off. oh and almost forgot have to disconnect the three wires that go to the lights bulbs for the coin tray cig lighter and gear indicator.... quite easy id say takes no more than 5 minutes to take off. hope this is helpful
Registered Driver
7th Gear
Thanks, guys.
Worked on it yesterday, I was able to tighten the nuts, after I seen that one came off, and now it is as good as new.
Thanks again.
AccRight
Thanks again.
AccRight
Hurricane Game
i'd have to say that this center console is one of the easiest to take apart that i've seen lol. maybe i've taken too many apart (eek), but mine came off pretty easy, and went back on good and easy as well. hey, i found change too!
Registered Driver
Originally Posted by Mike89Acord96TL
Ya thats crazy, mine gets loose, and then I tighten it, and it gets loose again.
ITSJESTER
17
12-06-2018 02:29 AM
dainmezron
10-16-2015 06:56 PM
