Just Got A 95 Tl
Just Got A 95 Tl
I picked up a sweet 95 tl from the auction for $4,300. It has 170,000 miles though. Did I pay too much. Also, the check engine icon stays on, and the abs light stays on (I can hear the abs module from under the hood making a buzzing noise for a few seconds at a time).
I'll post pics probably tommorrow.
i have a 96 and i believe my ABS light burned out. my module is noisy as well so i just took out the ABS motor fuse.. screw abs u dont need it. did u hook ur ecu to a scanner? if so what codes?
btw my has 140,000 when i bought it and i paid 2,000 all it needed was a pait job but my leather is warned out pretty bad.
i think u over paid dude... how is the engine running... tranny still good? any other problems with the car?
Registered Driver
Originally Posted by vishnus11
i dont think he overpaid....its just that YOU got a good deal on a sweet ride.
After registration, i paid $4,700. Should I get the codes and fix the ecu and abs, then sell tthe car? I want a tl with way lower miles, that way i could pimp her out with rims, taillights, etc.
If your engine and transmission are in good conditions, you may want to keep it and get some usage out of it before thinking of selling it.
But, check the CLE code first and you will have an idea how much the repair going to cost.
AutoZone will do a free scan.
Originally Posted by veo
nick how did you take out the ABS motor fuse? i got the same problem with it making noise.
Originally Posted by jerseydriver
i heard that 95 was the first year and they had alot of bugs but they were all worked out for 96
next to the ABS there is a small fuse box.. it says ABS on it. cant miss it.. there are few fuses in there.. take out one of them.. 15amp fuse. i did that and it never bothered me again..
thanks nick. i'll try to remove the 15amp fuse.
i believe my is a 95 as well... thats whats on the door but when i went to the dealer.. they are like son they began making 2.5 TL in 96 so i was like w/e so 96 then
IS there a fuse for the check engine light?
always good to try..
nick, it worked! the ABS noise is gone. The down side is now the TCS light stays on. is there a connection? or did i just loosen the TCS fuse by accident when removing the ABS fuse?
TL no more!
Veo, do you have the ABS light on all the time?? If you do, then there's probably a problem with either the modulator or the accumluator. If you don't have the light on all the time other than just starting the car, then the noise is completely normal. I usually get that whenever I start the car. If you pulled the ABS fuse, then the TCS light will come on. It makes sense because the TCS relies on the ABS to control the traction of your driving wheels.
Also, I tried what nick said and took out the 15 amp fuse in the abs box, but the abs light stayed on.
my car
Here are the pics of my car.
This is mt first time posting pics. If you cant see them, can you tell my how to post without having to click on a url( i think thats what it's called)??
no. check engine light can only be turned off by removing ur battery post.. or erased with a scanner.. do this take the negative side post out and keep it out for 10 seconds.. it should make the check engine light go away.. if it does come back which it probably will go have it checked out.. sometimes when u leave ur gas cap loose or maybe a fault reading accoured checj engine will come on.. if ur check engine light ever flashed on u.. u should immediately take it to a repair shop..
Hey thanks nick. I disconnected the battery and the check engine light went off. However I took all 3 fuses in the abs box and the abs light still stays on. How about that abs relay motor? The little bronze colored one. Would that need to be replaced maybe. If so, how much do they cost.
my TCS light has been on since removing the ABS fuse. Does the TCS light being on have any effect on the engine? I heard it can drain engin power.
i don't want to put the fuse back in because the annoying sound will come back from the ABS. i was thinking of taking out the TCS fuse as well. i don't mind having ABS and TCS lights on. i just want to avoid the annoying sound without damaging the engine. whats your opinion on taking out the TCS fuse? will that ensure that TCS is off and not draining my engine?
I disconnected the negative post to clear the check engine light..That worked. But now, my engine is idling a little irregular, like it drops down too low.
Also, i went to autozone to rent the scanner to check codes, but i dont know where to hook it up. All i know is there is supposed to be a plug under the steering wheel.
Hey nick, disconnecting the battery worked to clear the check engine light but now my engine is idling a little low.
its not under the steering wheel... look in front of the shifter there is a coin try.. or urs can be a ash tray.. ist under there... make sure u dont do anything stupid.. hook it up and make sure its secure then turn it on and the ignition... then check them and before u take it out turn the ignition to off.. hope this helped
umm veo when the TCS is off u get more power from the engine to the wheels and the rmp drops. when TCS is when u waste more gas and loose some power.. dont touch the fuse thats not the problem but do put the abs fuse in and check if the TCS light goes away... then take it out again thats what i meant...
thats weird..should not happen... even after driving the car was it still idling irregular
also by taking out the negative battery terminal u have deleted the codes. i dont think the scanner will be much help unelss the check engine like came back on
[QUOTE=nick96acuratl]thats weird..should not happen... even after driving the car was it still idling irregular
also by taking out the negative battery terminal u have deleted the codes. i dont think the scanner will be much help unelss the check engine like came back on[/QUOTe
Bro, as i was going in reverse, it was still idling weird. But after some time the idling seemed to go away. My car's playing tricks on me. Hey thanks for the help.
TL no more!
Dude, take it to Autozone and do a free computer scan. Find out what the problem is and report back here. You can't just disconnect the battery and see the problem go away.
IS this bad news?
O.K. So i went to auto zone and scanned for codes.
2 codes came up:
1) PO40 I think it was transmission
2)P400 i think. It said tcc or tss ( transmission control ...)
2 codes came up:
TL no more!
P0400 is a code for the EGR
I don't know what your other one is because that's not the whole code.
Here's a link for codes:
http://www.obdii.com/codes.html
TL no more!
Ok...how does the tranny shift? Is it like normal or does it shift weird? Is your D4 light blinking or is it off? I have a few options but my serive manual doesn't have P0700 listed.
