Jiffy Lube
Yes it's 5w30. I just got my car oilchange this morning. I have the Acura dealer do it.
I talked to them about the 2.5TL without remote keyless entry. You can't just buy the remote. You have to buy the whole kit, approx. $475 and $175 for labor. So it's almost 700 bucks for the keyless entry system. That's too much.
if you go to a local stereo shop, they should be able to upgrade your alarm, keyless, trunk pop, frickin tons of crap for $700 installed, for just keyless installed should only be $300 or less thats with an ok alarm
friend of mine got a keyless with siren and shock sensorS for $200 installed. and he can program the available 3 buttons for whatever. trunk, etc. he got it at Tweeter.
If you want the Keyless entry from the factory just order it from www.ahmotor.com I think it sells for $300 and you can install it yourself. I put it in and it took me no more than half an hour. All you have to do is remove the glove compartment and then to the right there is a location where you mount the unit and it easily plugs into the accessory plug harness which is tucked away in the right side kick panel. Its very simple to install and comes with user friendly instructions. That is if you must have a factory keyless entry in your car. I mean i bought it and put it in myself, but it would have been nicer if i had a nice alarm set up with remote trunk, windows and shock sensor.
Hope this helps.
Hope this helps.
asahrts
09-04-2015 05:55 PM
TSXEd05
AcuraZine's Hall of Fame
1431
06-14-2007 10:06 AM
