InTake??
Don't currently have on in my car, but I do have some in mind!
The Dragon Intake System from www.rswerks.com has one for the 91-96 Legend w/ or w/o TCS.
This one runs for $149.00 w/o shipping.
Then there's the one from NOPI
This one runs for the same..$149.
Not sure which to get, because I don't think anyone on the boards has either...correct me if I'm wrong.
weapon r dragon intake here from rswerks.com. i got this intake months ago before they were offering that "free gift". to me, its not the same thing as just adding the filter to the stock plastic piping because i went that way before.
Thanks...
Originally posted by KaMLuNg
one goes into the valve cover area and the other goes where the throttle body area.. u should see them both going into your stock tube..
lolz okay u gotta get a 180 degree mandrel bend 3" pipe.. they sell it at jcwhitney... since the pipe is basically U shaped... it has all angles in the U so u can measure and cut... lets say u have a 2.5 and the curve is more like an S than just a L shape... then u can make two cuts and combine the curves... measure where ur vaccum tubes go and drill holes... then add a filter on the end and boom u got a homemade intake...
i decided to paint the intake to match other parts in the engine bay so here is a pic of the tube drying...
here are the nipples...
so now the intake matches color w/ the throttle body cover and engine cover..
Originally posted by AC_DADDY
the nipple for the valve cover is not needed. just plug it up or run the line straight down. its for ventilation.
all it does is builds up carbon-soot in your intake and on the TB
rcs86
08-02-2016 06:52 PM
