Hyperflasing with 7440 LED's...
fight ninja! ya!
I recently just got some 194/168 LED's for my corner lights, which BTW look amazing. So bright! But I've seemed to run into a problem with the 7440 LED's.
When I put them in, they don't light up with the signal is on. But the rear signal lights hyperflash. I was wondering if there is a quick fix for this problem. Thanks.
1) Make sure they are in right (if they don't light up, you might have the polarity wrong - diodes need current going in the right direction) - take them out of the sockets, and put them back in the other way.
2) You'll need to get a load equalizer - I bought 2 from http://www.myroadster.net/. You just splice them into the existing lines with the supplied clips. THat solved the hyper flashing for me.
BTW - I found my corner LED's were too dull - they didn't seem to fill the reflector with light (but I didn't replace the ones in the rear), I assume you don't have the same problem?
Craig
Craig
Eggs999bacon
09-24-2015 10:08 AM
