Headlights bulbs?
Headlights bulbs?
I know it sound really stupid but I can't figure out how to change bulbs in the headlights. Can anybody tell me in details how to do this, please? I don't have a manual (which I will get for sure) now, and need the bulbs change as soon as possible. Thanks for all help, and pleas eprovide as much details as possible in the replys.
vigo98
vigo98
well for ur front driver side light u have to take out the reserve anti freeze tank... just pull up on it and also remove the little black box next to it... first thing to do with the light is to press the tabs on the harness that will allow u to yank it out... then remove the weather insulator around the housing... once that is out u should see a little metal clip that holds the bulb in... just unclip it... then the bulb should fall freely... replace bulb.. and reverse the directions to put everything back together... same goes on right side but not sure if nething obstructing u passage to the bulb or not.. i forget... but im sure u can reach it tho... good luck.. if need more detail just ask...
