Headlight wobble when roaming around.
Hi folks.
I have a problem with my passenger side headlight.
When Im roaming around with my headlights on, my headlight reflector part wobbles thus making my light beam go up and down on bumpy roads.
it is really annoying me. Anyone experience this kind of a problem? What are your solutions beside getting a new headlight unit?
Also, is it possible to remove the headlight unit without removing the bumper?
How hard is it to remove the bumper? Will the bumper align right oonce I re-install it?
Thanks folks.
Thanks folks.
There isn't a way to take the headlights out without taking the bumper off. If you take off your grill there are screws under there, then there are the screws on both sides next to the tires I think. The bumper should line right up when you put it back on. Remember if you take the headlight apart pre-heat it in the oven to soften the glue.
P.S. What part of RI are you from?
^ I smell mini-meet! RI is tiny enough, even if he's on the other side of the state, you can get there in 15 minutes, haha!
Probably the screws holding the reflector or the bulb guard are loose, causing the flashing. Take it out and take a look.
~Cheers~
~Cheers~
~Cheers~
~Cheers~
AmplifiedDetails
09-24-2015 02:55 PM
