grounding parking brake wire on navi
dont think im this stupid but yeah... i am... my new navi has the "cant drive and watch or reprogram navi" inless the parking brake is up. im getting it installed by a place so there def gonna do this. when i got in the back, find the red/white wire, clip it, and ground it... whats it good to ground to in the back of our unit? can i just put it in a splice clip and clip that to the ground of the stereo? or should i find a screw and actually ground it to the body somewhere? if so... where? ive never been back there. thanks for the help ppl!
Registered Driver
When I did mine for my headunit, shit, I'd have to check, lol, I forget at the moment (the color) but I just grounded it to the metal frame in the dash you see around the headunit, I think mine was green/white?
Originally Posted by KaMLuNg
u can just use the ground that the HU uses... tap it straight into that wire... what HU are u gonna be using??
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Registered Driver
Actually, they probably will ground it properly so that they are not responsible for anything if you were to watch movies while driving.
You want to ground that wire so you can watch stuff while driving, right? Or enter navi destinations or whatever?
it doesn't matter where u go as long as it is reading a ground... i would go off the HU ground because it is easiest...
Registered Driver
Originally Posted by copy252
my i screwed up my writings but thats what i meant. the place will install it correctly so the lock out is ON. im just gonna go in and clip the P.B. red/white wire and just ground it. I just wanted to know if i could use one of them splice clips and clip it to the HU's ground wire or should i ground it seperate to the actual frame of the car or could i use the metal frame around the HU. anyways, thats my intension.... so i can use the navi and watch dvd's and crash
lol
What you want to connect it to is something that is usually grounded, the ground from the HU, the frame, the metal around the headunit, even the latches for the doors could act as grounds (but look a little hack
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
And you should be able to use one of those splice clips to clip it tot he HU's ground as long as it is the right size, should just be a matter of choice, however you want to do it
I think grounding it with the "PB red/white wire" is what they are going to do, since I'm assuming there will only be current going through it when the parking brake is engaged.
and thats what i wanted to hear! cause it sounds the easiest! next thurday.... expect the pics!!! anyone else gonna get something like this or has something like this?
not on our cars... but i have done plenty of these installs on a few of the Dallas members CL-S... ill post pics when my pic host comes back online...
asahrts
09-04-2015 05:55 PM
