got the fog lights yellow condoms done...
but now i need the directions for turning on the fog lights without turning on the headlight switch all the way...i know, i have looked in the past forums and the directions was kinda wierd...so if any of you guys can just give me easy simple steps, instead of one whole page long on how to do this mod....that would be awesome guys...also i i got clear bumpers(finally) but anyways should i get plastic seal and seal it around the edges? please help
fight ninja! ya!
You can put a little "bead" of sealant(sp?) on the corners of the bumper lights. That should help prevent it from fogging up, water damage, etc.
Hope that helps.
Hope that helps.
All about JDM
I just put my clear corners in directly. No sealant, no silicon no nothing. Just put them right in. I have had no problems at all with condensation or fogging or anything.
If it does end up fogging up and stuff just remove it let it dry out and then put the sealant.
It's simple. There are 2 wires you need to splice together. They're in the same bundle. Go back and scan through the directions. Find the 2 colored wires they're talking about, and tap them together.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
