Fuel System Cleaner
thats a good question. what i use to clean my engine is filling my gas up at chevron. they have techron (not sure what techron does to your car) but its should be healthy for your engine if they're going to advertise about it. anybody know what techron is or what it does???
check these out
http://www.chevron.com/prodserv/fuel...tech_con.shtml
or
http://www.chevron.com/prodserv/fuel...derhood.shtml#
no spaces in any URL's
hope this helps
or
hope this helps
oh damn, thanks vigo!! that was all i needed to know. i guess ill be a chevron customer for a very long time! besides, chevron gas is one of the cheapest gas out there. here in tx, its 1.41 a gallon. it use to be 1.31!! :wow:
Don't use any of those fuel system/injector cleaners in a bottle. They don't do any good and are just a waste of money.
However, I have heard that the dealerships use something called K44 which is supposed to work well. I had them throw a bottle into my Legend but I didn't really notice any difference.
The best thing for your car is proper maintenace and a little bit of care from you to keep it running well.
Take a look at this LINK before adding any fuel additives in our car
http://www.ftc.gov/opa/1999/9909/shellcastrol.htm
It shows that claims of added power has never been proven and is mis leading advertisements.
however the fuel additives will keep down carbon buildup that occurs during normal use. Most additives has a chemical called thulene or something like that, I cant remember off hand but I'll correct it once I remember. It's 3am and I have an early flight out... Might be a while before I correct :-)
Nevertheless, it burns slower than normal fuel so the extra burn helps to burn out carbon deposits.
Also higher octane, slower the burn, lower octane faster the burn.
Higher octane, cooler the engine runs, lower octane, hoter it runs.
If you use high octane fuel, most places have their own fuel additives in their gas.
Some of you might remember a few months back that my Check Engine light kicked on due to a dirty exhaust manifold I was told.
The Dealer wanted $800 to take apart the manifold to clean.
I asked if my O2 sensors are bad and they said no, but the sensors kicked on due to very low air... meaning dirty.
They reset the light and I took the car home. I changed the plugs, put couple of fuel additives in and ran the car on the highway at pretty high RPM's ... I must have blew out the build up since the Check Engine light hasn't returned yet. (knock of wood).
I'll post if the check engine lights comes back.
Also Too much additive will cause damage since there are other additives in that bottle like mineral spirits and stuff.
I use fuel additives once in a while to keep the deposits down but it's only about once a year or so.
Mola
Mola
I put chevron techron into my 152K mile Legend. It seemed to idle a little smoother when it was warmed up and had a little more power. I figured $7 minus a $2 rebate, what the heck. If it blew up the car I'd have my excuse to go buy a new car. I plan on putting this in my wife's 105K mile Pathfinder. The venerable Road Rage had a post about using this.
http://www.acura-tl.com/forum/showth...hlight=techron
SinCityTLX
20
10-19-2015 11:23 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
