fuel pump
1) Remove fuel tank
2) Remove fuel pump mounting nuts on outside of tank
3) Remove fuel pump from fuel tank
4) Install in reverse order.
I would suggest purchase or download of a manual to have pictures and detailed guidance on each step.
Fuel pumps on Acuras are pretty tough. Why do you think the fuel pump is bad? I would suggest checking that power is supplied to the fuel pump and pump is not working before removing the pump. If no power suspect, main fuel relay or keyswitch.
good luck
good luck
IBankMouse
06-13-2020 12:53 PM
joflewbyu2
10-08-2015 11:16 AM
