front doors shake when at a red light stop.
lately, when I hold on th brake pedal at a redlight stop, the doors shake.
This didnt happen when I first bought it.
Anyone experience this? The weird part is it happens on my 2000 honda civic too?
Maybe its a honda thing.
Anyone know a fix?
Anyone know a fix?
Originally Posted by Ysidro
The vibration is from the engine.
Could it be that the engine mount is worn out?
How hard is it to change the engine mount?
And where is this part?
Engine idle speed control system is usually the problem when idle drops below 700 rpm. It should stay about 750-800 rpm at all times. If the Idle Air Control Valve (IACV) is dirty and blocked, the idle speed will drop under load (foot on brake w/ engine in drive) and idle will drop too low, increasing vibration substantially.
I would suggest cleaning the throttle plate and IACV w/ throttle body cleaner. Don't douse the electrical part in cleaner as it may damage the solenoid winding.
good luck
good luck
handsom-hustla
11-13-2015 05:04 PM
