Fog Lights....
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
I remember Din explaining how to get rid of the ugly yellow fogs. Something about just taking out the yellow that's in there. DIN, or anybody, can you tell me exactly how to do it??
Guest
Posts: n/a
Yeah, really simple. Pop open the hood, pull the plugs on the fog lights. Adjust the metal clasp so you can pop the bulbs out. Pop the bulbs out, but be careful not to touch the bulbs with your fingers. There should be two small phillips head screws (you may only be able to see one). Unscrew these bulbs and then pull out the assembly. Take apart the assembly and pop out those nasty used, yellow condoms.
i took mine out too...DO NOT unscrew fully the top screw. it will be a pain in the ass to get it back in. just loosen the top screw only. the bottom one is OK to take off fully though.
