Fog Light
Old Sep 26, 2004 | 06:56 PM
meazz1's Avatar
Fog Light
With the help of this forum , I was able to use quick splice to connect my fog light with parking light. Everything works great.
Only minor thing is, when the parking light s are turned off, I also have to remember to turn off he fog light. Is there a way I can have this turned off automatically or add any type of chime or beep , so I don't forget and run the battery dry ?
Bye the way, this is my second post here. It's a great forum and I am happy to be a part of this first generation TL users.
I am in GA., black 1997 2.5 TL owner.
Old Sep 26, 2004 | 07:56 PM
KaMLuNg's Avatar
if u connected it correctly ur fogs are supposed to turn off when you turn off your parking lights... i think you may have tapped into a constant +12V and it sets the master switch as ur switch and not the parking switch.. i would double check those wires unless i read ur post wrong...
Old Sep 26, 2004 | 08:06 PM
meazz1's Avatar
thanks for you reply KaMLuNg.
This is how I connected the wires. solid red wire with silver dots with the red wire that has a blue line running down its middle, and it also has silver dots on it.
Could you give me the correct wire colors to tap to ?
Old Sep 26, 2004 | 09:06 PM
WolfpackBill's Avatar
TL no more!
I've read that the 2.5TL wirings are different than the ones in the 3.2TL. The 3.2TL's fogs are controlled by the parking lights while the 2.5TL's fogs are controlled by ignition.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
