Flickering lights
Mine did the same thing. When I had the car serviced I had the dealer check the battery - it was bad and they replaced it free of charge. Since I've had the new battery -the flickering is almost unnoticeable. - its unlikely its an alternator - I have never heard of a Honda alternator going bad.
you could also check the ground terminal in the driver's side inside the hole of the fender, you may have to remove the cover that is near the head light housing. the ground terminal is a white plastic plug that has many wires protruding from it.
mada51589
05-03-2022 08:54 PM
tman570
06-11-2019 07:56 AM
