egr valve location on 3.2?
Khmer Pride
Originally Posted by copy252
took the cover off... didnt see it.... am i that dumb??? help!
Originally Posted by KrayzieDxC
right on the left corner of your engine cover,just look where the vacaum hose going to u'll find it
thanks man! how any good suggestions on cleaning the thing??? i know mines gotta look shitty in there... plus... i have no clue how to remove and i have no clue how or what to clean.... im stupid.... gotta learn sometime tho!
Khmer Pride
well i clean al the ports for where the EGr valve goin to engine. hmm theres a forum for it..well go to this link http://acura-legend.com/vbulletin/sh...php?t=68912..n i follow this DIY n it help me pretty much..i bought a new EGR valve. disconnected the negative battery first then unplug the egr plug n replace it n clean ever bit of the clogg.
went and tried step one this morning.... remove the hose..... NOPE! that little fuckers on GOOD!!! any special trick to diconnect it? all i tried to do is pull it and it seems glued on almost.... idk....
Khmer Pride
go to autozone.. and buy one of those rust bolts stopper it will losen the bolts a bit let it sit then take them out.hope ur using a good wrench to take off the bolts ..wouldnt be good if u use a str8 line wrench it will ruden ur bolts
I've found a short wobbly extension works wonders to access the nuts using a 12-pt, 12mm socket.
EGR is usally fairly clean. It's the EGR manifold distribution that usually is blocked.
A shop manual is essential for performing this maintenance correctly.
good luck
good luck
good luck
good luck
Originally Posted by bma4406
COpy
Did you ever finish your cleaning?
What do you use to clean the carbon out?
Khmer Pride
Originally Posted by meazz1
which end of PCV valve hose do you undo? PCV valve end or the engine end?
should be on the right side of the engine..its slanted a rubber house
SEAFOAM!!! its like the best crap $8.00 will ever buy!!! just let your car suck up like a half a can. put the other in your oil or fuel. The best way to do it is to get a plastic cup (i used a dunkin dohnuts ice coffee cup washed out cause i had finished it driving in to my house right before seafoaming ) anyways, cut the cup so itll fill about half the seafoam. Grab a friend and tell them to get in the front seat. now while the car is good and hot and still running. grab the pcv valve hose and tell your friend to rev it to about 2 and dont let it go more or less than that. let the hose suck up the SF nice and slow. youll see LOTS OF SMOKE FROM THE EXHAUST. after sucking is done (haha!!!..... sorry.... ), cut the car off. let it sit about 10 minutes. start her up! DONT BE ALARMED if she sounds like crap and look like she breaking down cause your barely getting any acceleration and theres TONS of smoke coming out the ass end! its the seafoam doing its thing. take her for a nice ride giving it some gas every now and then. your check engine light may be on for a little while to. also they recomend getting your spark plugs changed when you do this. also an oil change wouldnt be a bad thing either. both not SUPER urgent but id do it for the hell of it. hope this helped. ima seafoam my ES300 soon. only thing is i dont want to because changing the three rear plugs is going to be A PAIN IN MY A@#!!! ill prolly just wait till i got some extra money and have it changed when i get the timing belt done (in 40,000 miles)
WIll this affect my new o2 sensor aft the cat?
MetalGearTypeS
08-29-2016 08:28 PM
