Dual Beam HID's..
Dual Beam HID's..
well after wasting 3 hrs trying to put in a heavy duty wiring harness and having it blow out 3 of my bulbs and pissing me off.. i have decided to save up for a HID kit... does anyone have any suggestions on any dual BEAM his kits that are going for a pretty decent price??? thanks
Last year I bought a Hella/Osram 7000K Dual Beam HID Conversion Kit. I couldn't be happier with it. I started off buying those Hyperwhite bulbs about 3 years ago. Back then, they were $15 each! Now you can get a pair for less than $10. I went through a pair of those bulbs every six months and even had a heavy duty wiring harness for it. I figures I would just suck it up and buy and HID kit. It took about 1 hour to install. But I never did get the high beams to work correctly. But that's OK since you never even have to use the high beams once you get an HID kit. Oh yeah, I bought my HID set for $350. You could check eBay, or go to http://www.hids4less.com or just do a search for them.
go to groupbuys.com there are always group buys there for 350 on the hanabi hid kits ......but be careful i heard that in jersey they might fail you if the car did not come with hid's as oem equipment. As far has hid high beams ......no one puts hid's in the high beams because when u need the high beams halogens come on instantly where as the hid's have a slight warm up time for them to come to full brightness .... they do have bi-xenon kits ....but you will have to retrofit the housing for it and those kits cost an arm and a leg right now and only come on expensive euro cars.
good luck with the dual beam search, Ive been told that with most of the 300-500 dollar kits, its a cob-job as far as the highs go. Your best bet is not to worry about it that much, and find a way around that inspection thing... find someone who'll pass you for a couple extra bucks or something.. ask around, there's someone like that in every town
Ex-Mod
Originally posted by NsX Pilot
there easy enough to switch back to halogen for inspection anyway....takes about an hour
Originally posted by 96TL
An hour? Just unplug the HID plug from the H4 plug, swap the bulbs, and plug them in. 5-10 minutes at most.
Even if this set up was on my old legend it would still take a good half an hour.
Ex-Mod
most people try and mount it somewhere it will be hard to steal.
second arent you gonna remove the blubs and put them away somewhere safe?
Then after that wouldnt you cover the ignitor so that the contacts will be covered from the elements even thou its only gonna be for a few hours?
and i dont know about ur car but mine has a engine cover and there are a few plugs that have to be removed to even get to the housing?
Ex-Mod
BTW, I'm not trying to pick a fight with you, I just don't agree with what you're saying. On other cars it might take you a while to take out the bulbs, but on a TL it won't and thats what the question was in reference to. Our headlights are easily accessible.
