Drain plug washers
Drain plug washers
Ok, my plan is to change the transmission fluid, differential fluid, and coolant on my 97 TL 2.5 this weekend. Thing is the Acura dealer only had the washers for the differential plugs, they did not have the transmission plug washer or the engine block coolant drain plug washer. He checked with the Honda parts dealer as well.
What are the chances I can reuse the old metal washers for the trans and coolant drain without leaks? If this is not advisable, where else could I get the washers?
Update: I found that I can get the washers at just about any auto parts store problem is they don't show what size the transmission drain plug washer or the engine block coolant drain washer sizes are. Does anyone know the sizes on the 2.5?
大日本帝国
When I swapped my motor, EVERYTHING was re-used. You'll be fine.
~Cheers~
P.S. Since I lost a cotter pin, I used a paper clip to hold one of the castle nuts on the front suspension in place. Works a treat!
~Cheers~
ITSJESTER
17
12-06-2018 02:29 AM
MetalGearTypeS
08-29-2016 08:28 PM
Joe Avesyan
09-29-2015 03:57 PM
