Differential problem...??!
If you read the post about my nightmare than you may have seen the problem I had....
Sounded like dragging something....
Car wouldn't move unless hard gassed.... then shifter locked up...
Differential replaced for 1300 dollars....
Still same problem until I had to drive it home just a KNOCKING and JUMPING, SHUTTERING ect.
Problem is now almost gone, but there is a tick/knock that is consistant with rpm sometimes, when I turn the wheel more so....if the car is sitting, running, and I push the fender (sideways pressure on front wheels) the knock is louder... sometimes the knock isn't there.... WTF?
I am thinking that it might be a Bolt that Fell into the Tourque converter through a missing cover. There is a small cover by the tranny dipstick that is missing. This happens to be right in between two of the bolts that I found almost falling out of the tranny after last years rebuilds and there is a bolt missing just above the missing cover.
I am at a loss on this.....any speculation or diagnostic procedure advice would be a world of help for me.
09-15-2015 06:44 PM
