Deciding on mesh.
Old May 11, 2006 | 06:49 PM
esco786's Avatar
Deciding on mesh.
Hey Guys, I wanted to get feedback on what colour u think I should paint my mesh on my 96 2.5 TL. I have a dark green TL, currently with gold grille and emblems. Any recommendations? on colour/mesh type? And is it easy to install? I did some searching and found couple of DIY sites, but they apply to Legend. Same instructions as TL?
Thanks.
Old May 11, 2006 | 06:50 PM
esco786's Avatar
Maybe if you guys have meshes, you can post your pics in this forum to give others ideas...
Old May 11, 2006 | 09:22 PM
wackjum's Avatar
I have black mesh over my grille.
https://acurazine.com/forums/showthr...5&page=1&pp=25
It's not noticeable really because its black. But it looks better than the wide spaces the vertical slats make. The grille area would not be so black if the mesh wasn't there.
Old May 11, 2006 | 11:51 PM
TLBaller's Avatar
I have black mesh in my grill (the part btw the headlights)
Old May 11, 2006 | 11:54 PM
KADAW's Avatar
i have it black.. looks good IMO
Old May 12, 2006 | 03:29 PM
KrayzieDxC's Avatar
Khmer Pride
may be paint it gold,cuz u got gold emblems
Old May 12, 2006 | 04:24 PM
AJ3's Avatar
AJ3
3.2 Infatuated
I think the mesh looks pretty good to.. but where can we get a quality mesh panel?
Old May 13, 2006 | 12:50 AM
TLBaller's Avatar
home depot or lowes. get the kids where there is a diamond shaped holes.
Old May 13, 2006 | 08:44 AM
esco786's Avatar
I had the gold idea too. Do you recommend the home depot option for gold as well(painting)?
I found a nice site for idea of meshes. Ridiculous prices though..Contains pics of grille patterns (diamond, oval, hexagon...etc)
http://www.customcargrills.com/index.asp (GRILL MESH ON THE LEFT FRAME)
Maybe ill take a pic of my front gold grille and do some photocopy work to check which pattern looks nice.
Old May 17, 2006 | 12:37 AM
esco786's Avatar
to the guys that had the mesh for awhile, is the wear of the mesh worth it, but really mesh is replacable at a cheap price. but u guys see wear at a fast rate?
also, behind the grill, the black panel running across, does that have to be cut or is it removable? and finally, what puts the pressure on the grill to have it stick out with a curve.
Old May 17, 2006 | 03:09 AM
wackjum's Avatar
I made my mesh out of $1.50 gutter screen stuff. I just took off my grill and drew a rough outline. Then I cut the grill with tin shears. After conforming and test fitting, I cut some more off. To have it meld naturally to your grill, just bend the aluminum. Then I painted it with two coats of flat black paint. In retrospect, I should have used better paint instead of just cheapo acrylic stuff. Then I fastened it onto the exist slats using a few black zip ties.
Its been on for at least two years. I actually keeps bugs off my radiator I've noticed (huge bugs get caught on the screen instead).
Old Jun 3, 2006 | 01:04 PM
copy252's Avatar
i want my OEM grill dipped in CHROME.... omfg so nice! im not a mesh person
Old Jun 3, 2006 | 02:37 PM
TLBaller's Avatar
like this? it looks similar to the Blaze grill for the 2nd generation TL.
Old Jun 3, 2006 | 05:23 PM
UnsanePyro's Avatar
Registered Driver
I sorta like the way the grill looks stock, as long as the plastic is kept nice and black.
I've thought about doing a mesh setup behind the lower grill though, to try and keep it a bit cleaner looking, but haven't gotten around to doing it really.
Old Jun 3, 2006 | 10:26 PM
copy252's Avatar
i have a 3.2 so it would be up and down with the slats and i NEED the A!! but other than that... thats what i want!! where can i get that!!
xsilverhawkx
Oct 5, 2015 11:00 AM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
c1souk
Sep 28, 2015 11:20 AM
h22lude
Sep 27, 2015 06:22 PM
Froid
Sep 27, 2015 06:16 PM
