crank but no fire fixed..UNBELIEVEABLE! (pointer)
So one day for unknown reasons my 97 3.2 cranks but is getting no fire. long story short i check the ignition control module..nope. i check the misfire detetion sensor...nope. i check the main relay...nope. fuel pump...nope. fuel filter...nope. spark plugs...nope. crank sensor...nope. the last thing i check which should have been the first was the ground wire for the ignition control module thats located on the fuel rail...BINGO!! it was loose. tightened it down and it fired right up. 5 days later!..i feel so dumb but very relieved. so if anybody has this problem...crank but no fire no start..check that ground first thing then go from there.
The following 3 users liked this post by pro_found973.2TL:
SmokenTL420 (09-19-2012)
Yep took me about 5 days as well and that's after changing fuel pump, fuel filter and main relay was about to changed the crank sensor, thank god i saw this post.
Thank you, pro_found973.2TL
acuratl26
04-23-2020 07:30 PM
DerrickW
11-15-2015 05:52 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
