Comments please
Whats up guys? :yum: My car vibrates a little bit. :whyme: Is that something to do with the engine or transmission? I check the tires and suspension and they are fine. Anybody know why it causes that? Thanks in advance. :yum:
you might want to post this in the problem and fixes forum but there's already a thread in there about vibrations. read over it, this might be your problem.
https://acurazine.com/forums/showthread.php?t=151833 |
Its normal if it vibrates from a cold start around 1500 rpms. We have a 90 degree V-6 motor which tend to vibrate at lower rpms. |
take off each wheel and see if your wheels are bent. Also are you sure your wheels/tires are balanced? You also might need an alignment.
