Code P0135
Code P0135
Is it a common problem for an oxygen sensor to out right after one another?
I just replaced the secondary sensor 3 weeks ago and today the primary sensor went out.
This happened also 3 years ago, the same way one week a part, both went bad.
I have the P0135 code? iI is the O2 sensor heater circuit malfunction on bank 1 sensor 1.
Warner Brog has a direct fit one for $99.00, and the universal one is $49.00. Should I get the $49.00 one?
Originally Posted by Rondo
please post a link to the 02 sensor, local Honda Dealership wants $270 for the OEM 02 sensor you're talking about...I need to replace mine too (same error code)
You can buy the direct fit that with plug and go. The universal one needs the connector from the bad one to be attached. I never used the an universal one yet.
http://www.automedicsupply.com
update... oxygensensors.com could not obtain the supply from Walker, so i ended up canceling my order... ordered one off ebay from user id thegreasesquad and it arrived within a day... O2 sensor was replaced today... no more CEL... will drive a few more days and then take the car for inspection... i'm 2 months overdue
Jamus22
06-11-2023 10:08 AM
