Clear bumper lights
Basically look at the front of your car. Then look at the lower grill part in the bottom half of the bumper. Then go to the point where your signal light meets with the opening of the grill, there will be a small square hole in it. when your find that hole there is one star screw in that hole within a white plastic mounting bracket, stick your screwdriver in there and the job is half way done. It will be the same way on the opposite signal as well. Good luck!!
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
