Check Engine Light On
Old Nov 11, 2008 | 01:07 PM
main70072's Avatar
While driving to school yesterday, my CEL came on during traffic congestion. I got it checked and it seems to be the EGR valve. Does the dealer cover this part under the extended warranty for the 2.5TL if i have brought the car to them before under the warranty to change the exhaust manifold and oxygen sensor, but not the EGR valve. I still have less than 150,000 miles and is under 15 years.
Old Nov 11, 2008 | 02:50 PM
vas25tl's Avatar
The Box
I think they would cover it? anyone know? I would think the EGR is still covered under the emissions warranty.
Old Nov 11, 2008 | 03:41 PM
meazz1's Avatar
Call the Honda Corporate in CA and ask. They can tell you with the VIN if you are covered or not.
800-382-2238.
Old Nov 12, 2008 | 02:52 PM
bigwerm187's Avatar
Str8 Home built
what is this emmisson free thing..? so they will fix anthing that has to do with your exhaust..? or what..?
Old Nov 12, 2008 | 03:15 PM
andrew070489's Avatar
yes
Old Nov 12, 2008 | 03:36 PM
bigwerm187's Avatar
Str8 Home built
this guy meazz1 said to call the honda corp.. but every time i have to order a part from a dealership i have to go to honda to get it and they always tell me that hond is not with acura that honda and acura are differnt and bla bla bla crap like that...
Old Nov 12, 2008 | 03:55 PM
KrayzieDxC's Avatar
Khmer Pride
did you received a extended emission warranty?
i believe its 96-97 tl only ,
Old Nov 12, 2008 | 07:17 PM
meazz1's Avatar
Did you call the number I posted? It's for acura.
A call to the corporate resolved my problem when the dealer did not want to honor my warranty because I was at 155k with in the 4th year of the ownership. After talking to the corp, they agreed to fix everything even I was at 155k. I told them that they had a defective product and I could not be held responsible just because I used to do a lot of driving.
Old Nov 13, 2008 | 11:26 AM
bigwerm187's Avatar
Str8 Home built
ooooooo kkk i see what you mean. yeah i bleve mine got cracked when it was in a crash.. yeh i bough my car wreched so yeah. and my car got 215k on it
Old Nov 13, 2008 | 11:28 AM
bigwerm187's Avatar
Str8 Home built
what to you mean by that...? i bought my car from a guy i didnt buy it at a dealership. so whould that warrenty stuff still work..?
Old Nov 13, 2008 | 12:45 PM
main70072's Avatar
I bought my car from a private seller and when i brought it to the dealer to do the exhaust manifold warranty work they didn't say anything. So i guess it still works, but call just to make sure. I will have to call for my EGR valve whenever i have some free time.
Old Nov 13, 2008 | 01:19 PM
if i got a 1997 tl 2.5 190k on the odometer but a swapped motor with 80k (stock 5 cylinder) will they do this work using the swapped engines vin #? where can i find my vin on the block
Old Nov 13, 2008 | 01:21 PM
meazz1's Avatar
Good luck finding that on the block.
Block has some 4 digit number and somehow there's connection but no one seems to know how.
Old Nov 13, 2008 | 01:35 PM
so no luck? if i called honda do you think they would approve of that? me using the other engines vin? i mean that car isnt on the road so i hope they wouldnt care ha.. they probably will turn me down tho
Old Nov 13, 2008 | 02:21 PM
meazz1's Avatar
They may not find out.. if they are looking for it, than only they will know.
If you don't tell, chances are that they will not bother.
But, I am not telling you to do the wrong thing.
Old Nov 13, 2008 | 03:39 PM
ha i dont care about that, but the vin on my door will be no good. simply, is there a whole vin somewhere on the swapped engine that i can try to use..
Old Nov 13, 2008 | 04:41 PM
meazz1's Avatar
ok, why are you so concerned about the vin?, if your original vin has more than 150k, than you are out of luck. They really don't care if u put in another engine which has less mileage than 150k. By putting another engine in your car, you have already voided the warranty.
Old Nov 13, 2008 | 07:08 PM
oh thats all i wanted to know.. i thought since that acura didnt make it to 150k they would let me us it, but thanks
Old Nov 14, 2008 | 02:56 PM
main70072's Avatar
Just an update, I've just finished calling American Honda and they told me that if it's emission related, then just bring it to an Acura dealer and they will fix it. EGR valve is covered under the extended emission warranty.
Old Jan 27, 2009 | 10:22 AM
main70072's Avatar
My check engine light came back on again after exactly a month after bringing it to the dealer to have the EGR valve replaced free under warranty. It is the EGR valve again. How can a new EGR valve be faulty in only a month??
Old Jan 27, 2009 | 01:47 PM
^^^ the actual valve isn't always the problem.. since the valve is new the pipes are probably clogged with slug and stuff.. i recomment some seafoam and clean throttle body.. look it up in the DIY real easy
Old Jan 27, 2009 | 03:24 PM
KrayzieDxC's Avatar
Khmer Pride
thats retarded, they prob didn't put a effort in cleaning the intake manifold
when i fail my emission, i brought it to the dealer and they clean it all out , and inspect everything and till this day i havent had it back on..and lucky i got a letter for extension for it.
Old Jan 27, 2009 | 08:10 PM
main70072's Avatar
While the car was there with them the first day, the service adviser told me that they didn't have the EGR valve in stock for my car so they clean the throttle body that day. It was a friday so they kept my car over the weekend telling me that the part should arrive on monday and they put it in that day. As far as I know, throttle body has been cleaned and new EGR valve.
Old Jan 27, 2009 | 08:19 PM
vas25tl's Avatar
The Box
I that warranty
Old Jan 27, 2009 | 09:01 PM
Dozer's Avatar
In Ontario you don't have to have the engine light off to pass the emission test. Hehehe.
Old May 22, 2009 | 11:12 PM
main70072's Avatar
I was planning on bringing my car back to the dealer this summer regarding the EGR warranty for the second time but the CEL turned off by itself a couple of weeks ago and not coming back. I am thinking that Shell V-power have something to do with this because since then I only used Shell V-power because of their advertisements about getting rid of gunks in engine parts. I guess it works.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
