cel light
cel light
well i was driving on the way from the airport just now and my cel was blinking nonstop for about 20 minutes up until i turned the car off . any ideas?
no idea if it will do it agen until i drive it again later on today..
the cel did it again today and so i took it to jiffy lube . 2 problems
cylinder misfire and insufficient gas
cylinder misfire im guessin i would need to replace the fuel injectors or clean them? and i will seafoam the gas tank tomorow and hopefully it will clean the fuel filter because i really dont want to change it because i heard it was a pain in the ass
This may be a bad O2 sensor. If you had a fuel supply code ( you should state what codes were sensed), it usually means an O2 sensor fault. ECU knows nothing about fuel pressure or volume delivery other than what O2 sensor measure (fuel/air mixture ratio).
Spark plugs could be an issue also, but intermittent nature suggests more likely O2 sensor.
good luck
good luck
i will pull out one of the spark plugs and chekc if they were gapped correctly because my brother was the one who gapped them for me . the receipt from schucks says i have a 1 year warranty on them, and i believe this is what is causing the misfire (i chekced all the coil pakcs and they are still all good) . seafoamed the gas tank today, cant really feel no difference . will also look into the o2 sensor
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
