CAI on 96 2.5
looking good. so all the pieces are welded together and not bent? how do the welds look? would the results from the weld restrict airflow on the insde of the tubing? another question is will he be putting in the little tube thingy right before the throttle body? and one last question, any problems with water? it rains a lot here in the bay area, i haven't taken out the resonator box yet so i dunno how it looks behind the bumper. i might wanna get a bypass valve. well thanks for the pictures though. keep us updated on the CAI. I have first dibs
yep...they are all straight pieces welded together. i am not sure if the welds on the inside restrict airflow. i guess it does to a certain degree. the intake pipe actually points downward so you may not have to use a bypass valve....like the one from AEM?. the blow-by tube that you are refering to is just bent upward so it dosen't make a whistling sound.......aloha.........
lanechanger
10-13-2015 10:56 AM
johnpancakes014
09-27-2015 12:58 PM
