ON-BOARD MIL Diag. ABS, SRS, & CHKENG flash
You can access the MIL codes at www.batauto.com.
ABS codes are not available at any site that I know about. If you count the flashes of the ABS light, I can interpret them from my 97 2.5TL shop manual. The 3.2TL may or may not be the same. ABS codes are flashed slightly different than MIL codes. The flashes are all short flashes, w/ a 1-sec pause between the tens and units digits, so F-P-FFFF is code 1-4.
What are your ABS symptoms?
Good Luck
Good Luck
Jamus22
06-11-2023 10:08 AM
