Attn: INF4LIFE RE: h3 conversion
it isnt that hard all you have to do is take out the h3c bulb and there are 2 phillips head screws in there that allowsd you t take out the yellow cap and then put that back in withour the cap or spring and use one of the screws as a ground (with about a 6 inch wire attached) then you can put the h3 bulb in and run the 2 wires through the black gromet and use a male connector on ground and trim it so you can plug it in to one of the wires and then plug the posite(from bulb) into the other wire and then it should work .... you can figure out which is positive and negative through trial and error(if i remember the positive was the red wire
sorry no pics... the only benefit is that you can get hyperwhite bulbs i know PIAA makes a h3c bulb but the set is probably $80-90 and i dont want to pay that for a bulb
HondoGermany
23
01-08-2016 03:01 PM
09-17-2015 09:01 PM
