Any Side Marker DIY around?
Old 02-23-2009, 08:59 PM
  #81
98 3.2 Flamenco Black
Mandy's Avatar
Well...some research reveal that the washer reservoir indeed is on the driver's fender for 97 and 98. 95 and 96 are different.
Old 02-23-2009, 09:01 PM
  #82
Mandy's Avatar
It is possible to install it past the reservoir...need fender liner removal:
Old 02-23-2009, 09:03 PM
  #83
Mandy's Avatar
So some work and thinking required...I shall not waiver...I must proceed....the reward is worth it!!!!
Old 02-23-2009, 09:05 PM
  #84
Mandy's Avatar
For those who have the 95 and 96 you are good to go!!!
Old 02-23-2009, 09:12 PM
  #85
Mandy's Avatar
Guys I will post a DIY on this in the Performance Parts and Modification.....sayonara....!!!!
Old 02-24-2009, 12:31 AM
  #86
desired_speeds's Avatar
Originally Posted by Mandy
This is turning out to be cluster....sheet!
I will persevere and find a solution! I will break dow the fender liner! It could be that we will have 2 different locations for the markers....suits me fine. Nobody can tell anyway...you will always look at one side at a time!
dont do it! that so ghetto to have two different locations. I have a washer tank from a legend in the front fender if anyone wants it. its the same as the 95-96 ones.
Old 02-24-2009, 01:53 AM
  #87
B A N N E D
Let it Be's Avatar
Originally Posted by TLin401
You would most likely need a bigger relay to do this since it would be more power that the relay has to put out.
no additional relays needed just run the two wires from each of the sidemarkers (assuming they are JDM ones) to the corner light socket wires. black/black green/brown you cant get it too wrong, there are only 2 possibilities or which wires go where. ill post pictures tomorrow.
Old 02-24-2009, 02:37 AM
  #88
one more 194 bulb tapped into the turn signal isnt going to fry anything.
Old 02-24-2009, 07:35 AM
  #89
Mandy's Avatar
I have been checking cars around with side markers and they vary on location. We can install the markers pretty much around the fender and they will not look bad.
BMW places them all over the place. Subaru and Mitsubishi has them on most of their cars. Audi and VW have a few.
The plan is to locate both markers at the same place.
I was just entertaining the option of mis-matched locations, now really how can you tell…they will be ricey….LOL!
Old 02-24-2009, 07:37 AM
  #90
Mandy's Avatar
I would keep my washer intact. Once I get in there to see what location is available, I will be good to go! Thanks anyway!
Old 02-24-2009, 08:38 PM
  #91
Mandy's Avatar
Guys, check this out, I need feedback please!!!!
https://acurazine.com/forums/showthr...8#post10562218
Old 02-28-2009, 09:15 AM
  #92
Mandy's Avatar
Hey, somebody check out the proposed location of the side marker in the DIY...thanks...say yeah or nay, that's the only location available...but better than low...
Old 02-28-2009, 09:57 PM
  #93
Mandy's Avatar
DIY complete, check it out! I love my signal markers!
navtool.com
31
11-16-2015 08:30 PM
10-21-2015 11:38 PM
coykiam
09-11-2015 03:43 PM
Quick Reply: Any Side Marker DIY around?
