AC Control display burned out
Hey guys,
MY Ac control display started just turning off randomly. Then it started comming on when I started the car then turining off after 5 minutes.
Now it just does not turn on. Any Ideas?
Many auto electronics suffer from poor solder jts on the circuit board. Sometimes repair can be achieved by removing circuit board, inspecting w/ powerful magnifying glass, and repairing suspect solder jts.
If you're not into this sort of repair, I would look for a good used part using car-part.com to search near your zip code.
Download the online manual to understand how to access the display assemby.
good luck
good luck
^_^;
Actually, I have the same problem with my AC display, only, the blower will turn on randomly. I took apart my front console, and the stock wiring harness from the stereo seems suspect. There's a certain way I can jiggle it to stop it from blowing randomly. Sometimes, the display will show jibberish as well. It's an interesting problem to have = D
There is something I found in my manaul about the bulbs burning out. My control works fine, just that the display does not. It was actuall a feature that I really liked. Chose a temperatrure and get it. BAM!
ITSJESTER
17
12-06-2018 02:29 AM
calrow
05-03-2017 10:21 PM
adreano17
09-29-2015 08:48 AM
