ABS Ligh
ABS Ligh
Going to buy a 96tl tomarrow ... The abs light is on, so is the abs gone and need replaced or could it just be that the break fluid is low or something... and if the abs is done do i have to get it fixed for the car to run right or can i just go w/out it.. also how much do you think it would cost to fix to try and get something off the price since they are advertising the abs is working...
~Cheers~
ABS can usually be repaired, however if modulator is bad it may cost several hundred dollars for a used replacement. A new modulator is probably $2K, ouch but problems are usually wheel sensors.
If you're DIY, then you should be OK.
It's not a bad idea to have a good inspection by a competent mechanic or inspection service. I've usually found this to be a worthwhile investment.
good luck
good luck
Jamus22
06-11-2023 10:08 AM
mada51589
05-03-2022 08:54 PM
