abs help
abs help
alright, hres the situation. My abs accumulator was leaking at the bottom so I got a new accumulkaot/moduilator abs unit from ebay that came off a 96 integra. Ide tnical units for the most part. Bolted right into the stock frame and everything. Only problem is that the 6 hydrAulic line coming from thw wheels and brake cylinders etc. dont match up exactly to the inputs oin the integra unit. I kinda just used inution and some imaginative wire bending and hooked the lines up. (Hope this ? doesn't sound too confusing!)
The ABS doesnt make the annoying buzzin it did before. It works partially on dry pavement - it locks for a sec then activates, locks up complatewly in the rain, and works perfectly in the snow. So obviously I screwed up on the wiring. Is there anyone who can help me out with this. If u need a pic of the unit from the teg lemme know, and ill borrow a digi cam.
Thanks in advance.
Thanks in advance.
Jamus22
06-11-2023 10:08 AM
mada51589
05-03-2022 08:54 PM
