ABS/ Ground problem?
OK for some reason my abs light comes on then goes off, also around this time my radio will start acting funny, and resetting itself. I believe the problem could lie in a ground. I grounded the radio (TV) to the ecu metal case. U think this is the problem?
大日本帝国
Check the fuse in the kick panel. I HIGHLY doubt you grounded the HU to the ECU. The ECU is in the front passenger footwell. You probably grounded it to the ABS computer's casing which I'd recommend you ground it elsewhere.
~Cheers~
~Cheers~
SidhuSaaB
05-30-2020 12:40 AM
4drviper
09-23-2015 09:00 PM
rboller
09-23-2015 02:49 PM
